It's M6 (35ga I believe) versus the M19 (26ga) that the Vintage-spec Tonesluts and Pacifics are, or the M27 that the earlier Tonesluts were, so that will have a bearing. I'm not sure how the interleave will differ but the Stancors that the Tonesluts and Pacifics were based on were 'odd', as it has been described.Diablo1 wrote:Yes, I'm sure that would work fine and keep the output tubes happy. Would it sound as good as some of the other transformer choices?breakfastbuddy wrote:can you not just use a marshall 50w ot 3.4 k and missmatch it so it gives
6,8k that will be a easy solution
You'd also lose your 4ohm tap if that's important to you.
It'd be an interesting experiment though.
