I have not played with the 68k yet. I'm very happy with the gain/headroom balance so far. With the volume at 12:00 and guitar volume up, my guitar basically wants to play itself- very good response. Turning the neck sc pup down to 3-4 cleans it up pretty well.UR12 wrote: Doug
Have you played any with the 68k yet? If so what were your thoughts ......
My approach has been to build a rough bench prototype first and figure out what features I want before I start drilling holes in a nice chassis. So that's where I'm at now. I'm about to add a PPIMV to get the volume under control a little.
I'm dealing with a couple of issues right now:
1) Excessive buzz due to grid-blocking on the power tubes (I believe) - I solved 99.9% of that with Paul Ruby's zener diode fix, it really cleared that up dramatically. I have a couple other ideas to try for the remaining .1%, but I won't agonize over it too much right now as it is probably due to my shoddy "bench proto" layout. I also suspect one of my ecl86's is bad since it is redplating slightly while it is idling at only 50-60% of max dissipation. So I need to get a new pair of tubes and see what happens.
2) It's just a hair too bright. I am using a heyboer OT w/m27 steel and interleaved windings, 8k Zpri. Sounds great but it can be a little ear-fatiguing. I don't think it's the OT (and it could be the suspect tube). I alligator-clipped a 10-ohm/1-uf Zobel network on the 8 ohm spkr jack and that really helps. I hate to use a band-aid like that though and hope to get away from it. Right now I can't imagine using a presence control on this, but I'm going to add one to experiment.
So that's where I'm at, trying a lot of things and having fun. This amp definitely has the goods though. Just a matter of tweaking a little to get it to do exactly what I want.
Doug
