Quieten the Express
Re: Quieten the Express
12AZ7 has the same mu, ra, Gm, and Ia at -2V Vg as 12AT7, but filament current is 450mA vs. 12AT7's 300mA.
Using 12AX7's typical 100k Ra, fully-bypassed 1k5 Rk, the stage gains are:
12AT7 33.9 dB
12AU7 23.3 dB
12AX7 35.6 dB
12AY7 29.3 dB
Using that Ra and Rk, 12AU7 has a poorly-centered and very low-current bias point. The 12AT7 is centered a little better, but still at relatively low current.
donzoid
Post by donzoid »
Martin,
Looking at the specs, the aY7 is doing what I envisioned from the 5751. In other words it sounds like the aY7 is doing exactly what I wanted from that just a little bit less crunch and grind.
Fenderman - YES its got a fat midrange and very smooth. In fact after deciding to go with the aT7, I had changed the 500pF to about 380pF and they are polystyrenes...with this tube if I stay with it, I may go back upward a bit but I think just raising the presence and treble may do the trick. So far, a fun trial.
https://www.facebook.com/trialbyfirerocks
Be sure your tinfoil hat has a good low impedance ground.
