Handle on a Trainwreck head?
- LarryLarry
Re: Handle on a Trainwreck head?
Thats exactly how I did them
My eyes must have been blurry when I first looked at the pictures, I missed it. Now I see the slots in the 45 degree miter cut clearly. Nice work!LarryLarry wrote:Thats exactly how I did them
What size biscuits did you use?
- LarryLarry
They were size 20, not sure what that means though!  1st time I used a biscuit joiner.  I think I could have used smaller ones, but those are the ones my buddy had to go with his saw.  I think I read that Distortion uses 19 biscuts, I used 12.  2 at each 45 deg corner, 1 at each end of the front plate and 2 on the top of the front plate.  This thing feels like a tank now!
						- LarryLarry
Faceplate
1st coat of linseed oil on the faceplate.  The tree is a weeping cherry, which I'd never seen before moving to Georgia.
Very nice
A weeping cherry, never heard of that. I have a weeping maple in my front yard I had never seen that species of tree before I bought the house either.
Nice faceplate and amp.
- LarryLarry
Thank you Mark/NickC.  It certainly is a 'labor of love', and acceptable for a layman like myself.
Mark, Distortion did one of your cabs? His cabs look awesome. Do you know what he means by 'double stain application using alcohol'? I'm not getting quite the 3D grain I was hoping for using boiled linseed oil. Maybe I just need to keep applying and rubbing for a few weeks...
Distortions told me about doing a double stain on my cab but I can't remember what it consisted of.  Sorry.
- LarryLarry
A couple more pics put together - no handle yet; I haven't decided on that one.  I think I'll end up doing a mix of BOL, mineral spirits and oil based poly to get a smoother satin finish.
Looking great! Congratulations!!!
						- LarryLarry
Ok, well I think I'm done rubbing...
Nice looking amps. If you use a handle be careful not to get a cast one like I did, broke the soon after I put it on. :shock
Die cast zinc.  Make sure its brass or steel.
Great job with the cab. How many layers did you end up with? It gets a little obsessive after a while doesn't it?LarryLarry wrote:Ok, well I think I'm done rubbing...
- LarryLarry
Well, I had 5 coats of boiled Linseed Oil on it before I learned about wet sanding..  So I did this:
1. Mix of 1/3 Linseed Oil, 1/3 Mineral Spirits and 1/3 Minwax poly (gloss not satin, gloss is clearer/thinner).
2. Do the wetsand regime; start with 320 grit w/d, then 400 grit w/d then 600 grit w/d 3x.
3. Wax; use 0000 steel wool to apply the wax, let it sit for 10 or so min the had buff. Do this 3x.
4. Wax; jus like step 3 only use cloth instead of steel wool.
Like I said rub rub rub
Thanks much for sharing your routine. I will be using Tru-Oil but the process should be similar. I did the faceplate already and it took about 12 coats/layers. Can't wait to get the cab done as well.
