I was doing some playing earlier with this amp and ran into a strange problem. Well a few problems but the big one was that with my Tele (stock single coils) going through a 20 foot cord I made years ago, I was getting a strange crackle in the high end, not unlike popcorn popping. I swapped out tubes like crazy and played around a bit but the problem persisted. When I moved the amp to another room and switched to a Charvel with humbuckers and a different cord, the crackling completely went away. I went back to the Tele with the new cord and the crackling was again completely gone, everything sounded spot on. It may have just been the cord or the combo of that cord and that guitar, I'm not sure but more testing will inevitably reveal the problem.
The single coils are a problem themselves because of the amount of hum I get with them. None of my other builds hum this badly with single coils but then again, the ungodly amount of gain in this amp will of course pickup any noise that's getting interjected into the single coils. I might end up switching to a set of Joe Barden's (I'm a huge Danny Gatton fan) eventually to prevent problems at shows and practice but this guitar has not been any trouble until now.
Something else I noticed was that with the amp flipped over and the guitar dimed, tapping on all of the caps didn't give me the usual "thud" that I get most of the time. The amp was on and working fine so I'm not so sure why the microphonics went away, perhaps because I'm using a really nice set of tubes (Amperex 7025 in V1, Telefunken in V2 and V3, 1945 Sylvania 6V6's in the power amp). This tube combo sounds absolutely fantastic, I really dig the sound of 6V6's in the power amp. Doesn't clean up as well but the sound is killer nonetheless.
Also, my tube heaters are now running at slightly over 7V (like 7.05ish). My wall voltage measures quite high (125V so I'm thinking I need to add a set of antiparallel diodes to one of the heater wire connections. I don't want to carry around a variac to gigs..
The radio problem completely went away when I added a 10k Dale resistor to V1a, so thanks to Paulster for that suggestion! The amp is sounding fantastic now and aside from the high heater voltage, all is well in the amp it seems...at least for now
Cliff Schecht - Circuit P.I.
