bigbeck wrote:I'm assuming you followed the Jones Derailment schematic? No way you should have high voltage on pin 5 of the 6v6,or is that a typo? Check your wiring.
A bad ground at the cathode will give you a high cathode voltage.
You should have different voltages at pin 1 & 6 because the cathode resistors are different values. You'll even get a 10 volt or so different reading if they both had the same value cathode resistors. This is due to tube manufacturing tolerances .
Here's another clip of what it will sound like after you fix it
how the hell didn't i take notice of that
i will check that out when i get home
the schematic is more like the SExpress in this thread before the derailment ones, barring a couple of differences, pot sizes are different in the tone stack i have 1M for treb, bass and volume, and 25k for mid.
at the moment i dont have a presence pot in there so r24 is gong straight to ground.
it is cathode biased.i did have a 47uf in there but changed it for a 1000uf.
that clip sound good bigbeck
i will see what i come up with when i get home this arvo.
thanks for responding
cheers
Geoff
