Not too strange,other amps have used this method before. There were a few amps we have seen where a few tricks were used,and it does smooth out the top, and cure parasitics, also helps pic tubes to use in the preamp a bit better. But, the trick seems to be,without any tricksColor of wire in the heathers, also the fact that the heathers are wired in phase. If you look at Francesca's heather wiring goes out of phase from v1 to v2 (inverted) and then is inverted again from v3 to v4 to recover phase...strange...isn't it?
Now if you change things, you can make it different, thicken it up smooth the top end etc. But again,trying to use the same thing,and make it sound right. Even Ken himself had amps that just didn't come out right. Some may be a bit better sounding. Its like trying to unlock a combination lock, you may have 2 of the numbers, but it won't open till you figure out the last one.
Glen, yes he used those pots and others,or a mix in some amps, or that is what is shown in some pics..
Those were made for board mounting,kind of like early PC mounted pots.
No lug,just wrap around the leg of the pot, other amps use those too old Ampegs for one.. he used some other 2 watt pots too. Seems he didn't like those after they moved the manufacturing to mexico. the early USA ones he liked. Which you can still find those.
