Komet 60 Schematic...Accurate ?
Re: Komet 60 Schematic...Accurate ?
Looking at the three amps based on the #002 amp the first thing I noticed was the tube count one had four pre-amp valves another had six pre-amp amp valves while Aaron's amp had seven pre-amp valves. I also noticed that only one amp used an inductor for the filters.
I had a look at the Ceriatone amp, it has five pre-amp tubes and appears to have an inductor as there are two small transformers on the chassis.
From what we know which of the #002 amps can we rule out, they can't all be correct.
Yours Sincerely
Mark Abbott
Mark Abbott
They are all custom SSS amps, an interpretation of the builder.
So we don't have pictures or an accurate circuit diagram?
I thought I had something and this was it, pretty pitiful eh!
EDIT: I've noticed the closed thing we have is the Ceriatone SSS circuit.
Yours Sincerely
Mark Abbott
Mark Abbott
like a standard k60 except:drampaz79 wrote: ↑Tue Jun 16, 2020 8:04 pm Hi. Anyone can send me KOMET 60 schematic (Mark Knopfler LINDA)?
Thanks.
drampaz79@gmail.com
-5881s
- 220k plate resistor on the cold (3rd) gainstage
- 100k bias splitters instead of 220k
for k60, see https://ampgarage.com/forum/download/file.php?id=39517
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
Thanks! please can you indicate me on the layout where are these 3 mods for KNOPFLER LINDA VERSION of komet 60?
Thanks! please can you indicate me on the layout where are these 3 mods for KNOPFLER LINDA VERSION of komet 60?Roe wrote: ↑Wed Jun 17, 2020 7:28 amlike a standard k60 except:drampaz79 wrote: ↑Tue Jun 16, 2020 8:04 pm Hi. Anyone can send me KOMET 60 schematic (Mark Knopfler LINDA)?
Thanks.
drampaz79@gmail.com
-5881s
replace:drampaz79 wrote: ↑Wed Jun 17, 2020 9:47 amThanks! please can you indicate me on the layout where are these 3 mods for KNOPFLER LINDA VERSION of komet 60?Roe wrote: ↑Wed Jun 17, 2020 7:28 amlike a standard k60 except:drampaz79 wrote: ↑Tue Jun 16, 2020 8:04 pm Hi. Anyone can send me KOMET 60 schematic (Mark Knopfler LINDA)?
Thanks.
drampaz79@gmail.com
-5881s
- el34s with 5881s
- 220k bias splitters (connected to pin 5 of the output tubes) with 100ks
- 100k v2 anode resistor with 220k
4x12" w/H75s
4x12" w/H75s
Thanks a lot! Theese mods LINDA For knopfler komet 60 is from official source?Roe wrote: ↑Wed Jun 17, 2020 11:58 amreplace:drampaz79 wrote: ↑Wed Jun 17, 2020 9:47 amThanks! please can you indicate me on the layout where are these 3 mods for KNOPFLER LINDA VERSION of komet 60?Roe wrote: ↑Wed Jun 17, 2020 7:28 am
-5881s
- el34s with 5881s
search the forum for the source
4x12" w/H75s
4x12" w/H75s
Hi. Anybody has specific for PT, OT CHOKE for komet 60? Thanks
Allynmey could tell you the Heyboer transformer set to order. It should be in this site somewhere.
Here is the link about the Mark K mods.
https://ampgarage.com/forum/viewtopic.p ... met#p80226
Yours Sincerely
Mark Abbott
Mark Abbott
thanks!Mark wrote: ↑Thu Jun 18, 2020 10:26 pm Allynmey could tell you the Heyboer transformer set to order. It should be in this site somewhere.
MK mod is described here:
https://tubeamparchive.com/viewtopic.php?t=7665
and it basically consists of:
"Replace the two .02uF PI Caps with .047uF OD's
Replace the two 220K PI>power tube grid/bias resistors to 100K
Change the V2 Plate resistor from 100K to 220K
There you go. Bias it a little hot."
Power tubes used are 5881.
4x12" w/H75s
4x12" w/H75s
