Rocket w/ Reverb
XgamerGt03
Re: Rocket w/ Reverb
Post by XgamerGt03 »
martin manning wrote:
XgamerGt03 wrote:
martin manning wrote:I'm still looking at V2a's plate being 55V when it's supposed to be connected directly to B+4, which is 83V.
I wonder if V2b is being used as the cathode follower. Its plate is at 82V in this case. I can't see the pictures while I'm here at work but you may want to check to see if that is the case. I don't see what would cause it to be 55V unless he has a resistor soldered to the wrong place.
Yes, that looks like the case, and V2a and b appear to be wired correctly, but, the cathode resistor on V2b doesn't look like 56k.
I can't tell too well at the moment. I'll take a look at that when I get home. So that's another thing for him to look at.
EDIT: Your right. I can't tell what the value is but it doesn't look like a 56k or a 100k like I have seen. This should be checked first.
It's suppose to be a 68k resistor there based on the layout he is using.
amplifiednation
Post by amplifiednation »
M Fowler wrote:It's suppose to be a 68k resistor there based on the layout he is using.
I think I'm on with the 68k. I gotta get some better data and get back to you geniuses. I am up in the mountains of new hampshire and need to get back to the build
Amplified Nation
www.amplifiednation.com
@ampnation
angelodp
100k 68k
Post by angelodp »
Edit - looked closer and the 100k looks correct but the 68K?
Are we talking R7 68k or R8 100k
It's R7 on the schematic, shown as 56k there. Hard to tell for sure, but the pic looks like a 120R on the board. A small value would explain the high current draw from B+4 and the low voltages we're seeing.
Taylor, this can wait! You need to enjoy what ever it is you're doing up there and whomever you're doing it with. BTW, I climbed Mt. Washington one beautiful sunny late-December day... what a great place!
amplifiednation
martin manning wrote:It's R7 on the schematic, shown as 56k there. Hard to tell for sure, but the pic looks like a 120R on the board. A small value would explain the high current draw from B+4 and the low voltages we're seeing.
Trust me all I want to be doing is getting the amp running! There was like a foot of snow here too. Will just a few hours and hopfully this is sorted out!
Amplified Nation
@ampnation
angelodp
Voltage chart
Post by angelodp »
I have not done readings since I added the reverb circuit. Here are my voltages. My topology varies slightly from Normster's so it will reflect on the tables.
[IMG:1969:2603]http://i260.photobucket.com/albums/ii9/ ... hart-1.jpg[/img]
amplifiednation
So finally made it home. I don't know if that resistor is correct. Honestly I can't read the colors because it's so small.
When I bought the parts I was supposed to have 10 68k resistors and I can't find the bag (I have all the others) so I'm not sure if I used the wrong one, because why would it look so different than the others??
Amplified Nation
@ampnation
Looks like 100 ohms brown-black-brown-(gold +/- 5%)
What does your DMM say?
XgamerGt03
That does look like a 100ohm resistor, which would explain the huge drop in voltages. You could really use anything between 56k and 100k if you had those for now.
Check it with your multimeter and see what it says. If it is in fact 100, or really anything below 56k you should replace it with a larger value.
Ange your voltages look good did you run your reverb driver from a node other then the B+2?
amplifiednation
Here's my voltage chart. sorry the file kind of got mangled with a free PDF editor software i had to grab to manipulate the file
Amplified Nation
@ampnation
V1 and V2 has some real issues to sort out.
amplifiednation
M Fowler wrote:Looks like 100 ohms brown-black-brown-(gold +/- 5%)
So I'm not sure my DMM is working right?? I can't get a reading on it and it's an auto range.
I just changed the batteries too.
Weird.
I've got another cheapo radio shack one around here and at the lowest range of 200, it's measuring that resistor at 100.
So could that be it?
I have a 47k here and a bunch of 33k. Can i put two 33k in series to get 66k? I don't know how I made that mistake. I have 100k as well.
Last edited by amplifiednation on Mon Feb 28, 2011 12:47 am, edited 1 time in total.
Amplified Nation
@ampnation
amplifiednation
M Fowler wrote:V1 and V2 has some real issues to sort out.
I'm hanging my head.
Amplified Nation
@ampnation
