Rocket with 6V6s - Anyone built one?
RJ Guitars
Re: Rocket with 6V6s - Anyone built one?
Post by RJ Guitars »
Rich,
Cool amp and great inspiration!!!
I have been doing some of the obligatory digging on this topic and of course it's been hashed around before. Here is one other thread with some good stuff...
https://tubeamparchive.com/viewtopic.php?t=3432
I was specifically looking for a good starting point for the Cathode bias resistor value on pair of 6V6's. Does 250 Ohms seem reasonable??
rj
http://www.rjguitars.net
rfgordon
Post by rfgordon »
rj,
On that amp I used one of Matt's (musicalpowersupplies.com) 325V PTs, which, iirc, put about 405VDC on the plates. So I think I used a 270 ohm RK for the power tubes. It might have been 300 ohm, though, I don't remember, and the pic doesn't show it. That big voltage gate the amp tons of punch! Unfortunately, Matt's sold out of those PTs, and has been for a while now.
Rich Gordon
skyboltone
Post by skyboltone »
RJ Guitars wrote:Rich,
rj
Hey Rich, try an adjustable just for grins. A wirewound 500 ohm will allow you to run them hot or mid or cold. Just a thought.
rfgordon
Post by rfgordon »
skyboltone,
There you go giving me more ideas again! I suppose I could also put a minimum-safe value R in series with a wirewound pot, to get a more customer-proof arrangement. Hmmmm, now you've really got me thinking.
BTW, still diggin' that Carlton LP. Thanks again.
Rich Gordon
RJ Guitars
Dropping String Resistors - 6V6 Rocket style amp
Does anybody have a strong reason toward preservation or deviation from the dropping resistor values used in all the Trainwreck amps, when building a 6V6 cathode biased Rocket?
The 18.2K - 9.1K - 9.1K combination seems like it works well so no argument with success where the technology has been proven. Just wondering if 9.1K - 4.5K - 4.5K or any other combination of resistors with that same ratio would cause a problem since the "ideal" end voltages at all the B+ nodes has yet to be established for a hybrid build idea like this?
Curious what light the wise and savvy might have to shed on this?
rj
dave g
Post by dave g »
I would probably run the PI at a higher voltage because 6V6s have less gain than EL84s, so to get a similar amount of drive from the output tubes you're going to need a larger voltage swing coming from the PI.
I would try to get your PI voltage to around 280v, while keeping the preamp around 200v.
If you are running normal rocket voltages, try something around
10k - 22k - 9.1k
I might also consider changing the PI tail to around 20k and the cathode resistor to around 500-800R
Zippy
Post by Zippy »
dave g wrote:I might also consider changing the PI tail to around 20k and the cathode resistor to around 500-800R
Ref.: The AB763 blackface Deluxe Reverb uses 22k/470R with a 12AT7.
