Express Premium Board
Re: Express Premium Board
Cause i want a different way to solve this issue
Fair enough.
- Littlewyan
I've never seen that done before! See how you get on with it. Might work. Just watch for burn marks on that board! Once the amp is up and running, play it for a bit then feel around the board to see if the board is dissipating a lot of heat.
- johnnyreece
I know it's a bit late for it now, but it might have been worth drilling a couple holes in the board where the heat sink was mounted for a touch more ventilation.
Nice looking build.
Will VVR be a part of this build, these amp are quite loud and bright?
This is probably the factor which stops me jumping in on a build, how to do it right using the regular caps.
The norm seems to be can caps, but I don't want to go down that path as I already have the caps I'll use.
Yours Sincerely
Mark Abbott
Mark Abbott
That heat sink is looking super nice, Dave. I think that's a great idea. Too, I know Glen has said that his resistor (traditional ceramic coated block type) gets really warm in his amps. I don't experience this so I wouldn't be surprised if it had performed perfectly the way you originally had it.
But you've moved well past this potential stumbling block at this point, carry on...
Mark, what you mean by VVR... is it about the tube ?
Ross, thanks !
I do believe that heat sink will add more potential to the Resistor
Ross, thanks !
Hi Dave
Here is one of the VVR threads.
https://tubeamparchive.com/viewtopic.ph ... hlight=vvr
Most people have the VVR pot on the front of the amp. I would prefer to keep the look of the amp the same and have either the presence or the VVR pot on the back of the amp.
If I were to also include a resonance pot then having the presence and resonance pot on the back of the amp would make sense.
I hope this is of some assistance.
https://tubeamparchive.com/files/preson ... r2_181.pdf
There is this too by Martin Manning.
Yours Sincerely
Mark Abbott
Mark Abbott
Hummm....
I need to heard the VVR .. if you got a clip on a Express ?
But I'm not planning put VVR in this built.
Hi Dave
I've heard the amp in person and it sounded the same but quieter which I liked. This is what I can find on the VVR on You Tube.
https://www.youtube.com/watch?v=mlb4dbfbEJ0
https://www.youtube.com/watch?v=42R1uajFJnY
There can be an issue with the guitars volume pot being scratchy if the voltage gets too low, but that isn't a big deal in the scheme of things, and a capacitor fixes that.
Had you given thought to a resonance control?
Barry Marie's (Barwatt amps) has his amp tricked out with this sort of thing and I hope to hear it sometime this year. Unfortunately this will come too late to assist you with your build. I have only heard an amp he built for a guy with VVR.
Yours Sincerely
Mark Abbott
Mark Abbott
Looks good and I believe that is a Watts chassis you drilled out right?
guitarmike2107
I like polystyrene caps, plus they can be orientated for lower noise, pulled all the mica's out of a high gain amp I built and replaced them with polystyrene caps and the amp was much quieter and sounded sweet.
Nice looking built Dave
I order a Blank Chassis and drill it myself with a Milling at my shop.
I have now finish school and get my Welder Diploma !
so, i have much more time for my project !
Here is a little photo up-date
Thanks All for help and great comment !
