No need to ask why they went that route... IMO the pot bushing should not be counted on to ground anything except the pot housing.RJ Guitars wrote:Fender and other manufacturers routinely soldered to the back of their pots.
Really frustrated with PEC Pots
Re: Grounding Tabs...
hitchcaster
Re: Really frustrated with PEC Pots
ive soldered to pec pots fairly easily.... use a Dremel metal brush to scuff them up, and wonder solder works... doesn't have to get crazy hot.... Im sure all of solders won't work tho
I solder 14 gage solid wire to a terminal lug and bolt that to the chassis. I bend everything so that it runs parallel to the chassis. The end of the ground buss that is the farthest down the signal is the terminal lug end. I ground everything though the phase inverter to the ground buss in the order that they are in in the signal chain. I have built three amps and they are all very quiet for tube amps.
Solder on,
George
Solder on,
George
Paultergeist
Slightly off-topic, but those are really, nice clean build photos, George.
Is that an in-line fuse off of the PT center-tap to ground I see?
- RJ Guitars
Great technique... nice looking work.George61 wrote:I solder 14 gage solid wire to a terminal lug and bolt that to the chassis. I bend everything so that it runs parallel to the chassis. The end of the ground buss that is the farthest down the signal is the terminal lug end. I ground everything though the phase inverter to the ground buss in the order that they are in in the signal chain. I have built three amps and they are all very quiet for tube amps.
Solder on,
George
http://www.rjguitars.net
It's a 0.5A fast-blo HT fuse. I'm not exactly sure why it's there other than it was on the schematic so I put it in.Is that an in-line fuse off of the PT center-tap to ground I see?
Of little or no interest: The Marshall clone blows the Trainwreck clone out of the water. I'm working on that.
Solder on,
George
- RJ Guitars
Great little no interest statement... It would be cool to hear some clips from the starting point and listen for the progress as you work on that. When a Wreck is doing everything right they should be a little Marshally but with added flavors. Maybe a journey worthy of a thread?George61 wrote:...Of little or no interest: The Marshall clone blows the Trainwreck clone out of the water. I'm working on that.
Solder on,
George
