Where to buy solid core wire from?
johnnyreece
Re: Solid wire sources
Post by johnnyreece »
Richie wrote:
Hepcat wrote:Weber has the solid core pvc insulated wire by the foot but it has the woven cloth over the pvc. I use it for filament leads because I use the 18 gauge size but while the cloth covering has the "cool vintage" mojo, it's a pain in the butt to strip as my auto stripper doesn't work on the cloth. (run-on sentence, oops!) Weber does sell it by the foot in different colors so you can buy only what you need.
If its the old fender type, the real stuff which you can get, you don't strip it. You just cut it, then push the cloth back. Its called push back. Some of the new made cloth covered does have a inner coating,which then it does not work like the old type wire. I think they upgraded it, just made to "look" like the old type. But look up fender push back wire, you should see it come up.
It's definitely got a coating under the fabric that doesn't push back very well. That said, I still use it. I like the cloth look, and they have purty colors! :oops:
