Transformer sets available.
tjauernig
wreck xformers
Post by tjauernig »
Allynmey,
If there are any transformer sets for the express still available, I would like one.
email to tjauernig@verizon.net
T. Jauernig
paulruby
Re: Transformer sets available.
Post by paulruby »
Bump... I just got ten more sets and they need a home. I have too much stuff!!! These are my version with only 300VAC on the PT an donly 5.2k on the OT.
I also had a run of chassis made to MY layout, which is like this:
http://www.paulamps.com/DSCF0135.JPG
http://www.paulamps.com/DSCF0136.JPG
http://www.paulamps.com/DSCF0137.JPG
But, the power tube holes are not drilled so you can make an express, or rocket or what ever you want. Good for any amp with similar layout. These are 17x7x2.5 inch. Made for a 2.5 in wide turret board, 9.5" long or longer and the power board can be about 3x3.5 inch.
I can drill the power tube holes if needed. And, I can post pics of the actual blank chassis when I get a chance...
- Paul
Allynmey
Site Admin
Post by Allynmey »
They are nice paul. Does it come with the strengthening blocks? How much?
paulruby
Post by paulruby »
I'll post some pics when I get home tonight. These do not have the end blocks but do have threaded inserts for mouting to the cab. $55 each shipped in the US and I'll drill which ever power tube configuration is desired.
Obviously, the big difference versus others out there is that these were made for me, so are my layout scheme. But, this chassis is versitile enough for just about any single channel amp design. The standard iron mates exactly and it is drilled for a JJ 40x20x20x20 can (which I use for just about every style amp I build).
I have the can caps, too. So, if anyone is looking for a jump start, I have chassis iron and the can caps. That would be $235 for the combo.
By the way, I have no desire to become a kit or parts dealer. But, I do buy the expensive stuff in quantities of 10 or 25 so will always have enough extra to sell a few for a little above my cost. Win-win situation for us small time-builders.
paulruby
Post by paulruby »
Chassis picks... Still without any power tube holes drilled...
http://www.paulamps.com/wreck_chassis1.jpg
http://www.paulamps.com/wreck_chassis2.jpg
http://www.paulamps.com/wreck_chassis3.jpg
17x7x2.5, so is more like a jtm45 than a wreck. But the moutning lip is internal and it's drilled for the wreck iron and such. Also drilled for a large can cap (jj 40x20x20x20 or similar).
Turret board mounting holes are 9.5"x2.5" and two of the holes are shared by the OT. A power poard is indended to mount to the PT mouting bolts.
- Paul
