My "Twinwreck" Express combo build
fishy
Re: My "Twinwreck" Express combo build
Post by fishy »
Congrats... that is a cool looking combo for sure.
Look forward to the clips.
ampbldr2
Post by ampbldr2 »
This is cool! What is that black tape inside for near the supply caps?
Notice any vibration issues in the cab?
Noval_novice
Post by Noval_novice »
That is truly beautiful!
vincenz
Post by vincenz »
ampbldr2 wrote:This is cool! What is that black tape inside for near the supply caps?
The black tape is simply to mask 3 holes drilled by error :oops:
Regarding the vibration issues, that's precisely what I have to resolve right now.
The cab is strong and rigid, there's nothing to worry about that.
But I have some microphonic interferences with some particular frequencies. No feedback, but some high pitched "chimes" sounds, especially when I play with the neck pickup (lot of bass), e.g. the C note on the 5th string...
I have tried a lot of different tubes, in particular some good NOS 12AY7 (from Mike) well-known to be very quiet and not microphonic at all.
Maybe the chassis is mounted too firmly into the cab, I will try to isolate it with some rubber or so...
Someone here had experienced the same issue with a combo :?:
Yes you need to use some cushioning between the chassis and cab so the vibration is lessened.
Also may need to add o-rings to the power tubes.
vincenz
Post by vincenz »
Yep, I will isolate the chassis from the cab using soft rubber tapes and some rubber washers for the screws.
I wonder if it would be useful to also work around the fastening between speaker and cab ? :?: :idea:
And I just ordered some tube dampers....
fishy
Post by fishy »
Rooster brought this little mod to the forum and it might be worth looking at as it directly addresses vibration related issues.
https://tubeamparchive.com/viewtopic.ph ... ht=express
Not too sure how many others have tried this to tame V1. I ordered one but have not got round to installing it.
vincenz
Post by vincenz »
thanks for the link. Very interesting thread...
Tri-tube ring ordered ! :D
