redshark wrote:To all the trainwreck experts....
is this the inside of a real wreck?
In the thunderfunk webpage this picture was posted as the gutshot of a rocket but seems to be a Liverpool build.
See the mix of diferent pots, second shielded wire from pin 2 V1 to volume pot, also there a grid resistor same pin 2 and the shield seems to be connected to the plate pin1, that one in Gerald Weber's book is a trick to stop oscillations and so is the grid resistor. Check also 100k plate resistor has a ceramic cap across, that one seems to be other little band aid and so the other cap in parallel to the 0.0022mf pvc cap, there's a ceramic maybe same value, reminds trudy.
It seems that Ken or whoever put this together had a very temperamental build and tried to stop oscillations everywhere....
That amp was built by Dave Funk and tuned by KF for a guy that used high output super distortion humbucking pickups. They had to "dumb" the amp down to work for the guy.
