Rocket Combo Takes Off
dartanion
Re: Rocket Combo Takes Off
Post by dartanion »
Looks great Ron!
That's a nice color combo as well. I built a DC30 head for a guy a few years back in that same combination. I was tempted to keep it looked so nice.
hendo
Post by hendo »
Dang ... that looks awesome. It so nice to see the faceplaces made out ... they look so much better in context on the amp as opposed to when I had it in illustrator.
Okay, okay ... it sounds cool, but does it look cool?
rawnster
Post by rawnster »
Thanks guys! Black is still the new Black. :) Pretty cool looking. I'm definitely building one for myself now.
Thanks Hendo, for your Illustrator magic. Very old-school chic! 8)
Zippy
Post by Zippy »
Be sure to give yourself enough room in the baffle for a 2x10 option. ;)
They might almost fit the cabinet that you have now (on the diagonal).
rawnster
Post by rawnster »
Zippy wrote:Be sure to give yourself enough room in the baffle for a 2x10 option. ;)
I hear nothing!!!! :)
[img:460:300]http://conservativedialysis.com/~mnick/ ... lalala.jpg[/img]
Man, that is yummy!
Very pro look all the way. :D
rawnster
Post by rawnster »
Structo wrote:Man, that is yummy!
Thanks Tom. I tweaked the PI last night and tried some KT77's. Very nice! Much nicer overdrive tones--tighter low end. Perhaps KT66s have a touch better clean sheen, but overall, the KT77s may stay in this amp.
Hmmm, I should try different power tubes.
I have just always kind of stuck with the 6L6 or 6V6 flavors.
I do have one amp that is 4 x EL84 that will blister paint. :lol:
txbluesboy
Post by txbluesboy »
Nice amp Rawnster, I've been thinking about converting my Express into a Rocket/Rockster type amp. I also am a fan of reverb and have used the 1 tube reverb and liked it. Did you use a mix resistor and series it in the circuit or run it to the non-inverting side of the PI Vox- Matchless style?
rawnster
Post by rawnster »
txbluesboy wrote:Nice amp Rawnster, I've been thinking about converting my Express into a Rocket/Rockster type amp. I also am a fan of reverb and have used the 1 tube reverb and liked it. Did you use a mix resistor and series it in the circuit or run it to the non-inverting side of the PI Vox- Matchless style?
Thanks txbluesboy. To answer your question...picture says a thousand words. :-)
txbluesboy
Thanks for that. I thought you used a single tube reverb. I'm going to copy yours if you don't mind.
Terry
rawnster
Post by rawnster »
txbluesboy wrote:Thanks for that. I thought you used a single tube reverb. I'm going to copy yours if you don't mind.
Terry
I don't mind at all. One edit on the schematic is that I'm actually using a 1k2 resistor on the reverb driver cathode, not 820ohms. The reason is simple, I didn't have one on hand when I put it together. However, I think biasing the tube slightly cooler is part of the subtlety of the reverb effect that I really really like. It's your call though. Either way it'll sound very good.
breakfastbuddy
pictures says 1000 words if you can see the details
Post by breakfastbuddy »
sloppy pic with no detail ?
breakfastbuddy
sorry my mistake , its good with good detail :)
txbluesboy
I don't see anything on the schematic showing your "Lift" option. Are you lifting the connection to ground below the bass pot, leaving the mid pot functional?
