Best Output Transformer
RJ Guitars
Re: Best Output Transformer
Post by RJ Guitars »
soma_hero wrote:RJ, I'd be interested in getting one of those A470 clones from Edcor on the M6 steel for a Rocket. Was that something you had done spec wise? Or was that just for other amp projects?
Soma - Mark has that correct, the EDCOR is not a DYNACO clone. I did have them wind an output tranny for me at 35 watts, with dual primaries at 4.3K & 5.2k, using M6 steel, but it is their own design. These trannies were derivatives from their HiFi line so in that respect it should have good sonic qualities like a Dynaco, but I can't tell you yet how they compare. I was thinking of the Rocket amp when I had this wound, including my hybrid Rocket build with the KT66 output tubes. I've also had them wind a 5.2K and 6.6K version of the same transformer.
Mark is using one of my EDCOR wound 245-0-245 250mA power trannies... which so far have worked out excellent. There are only a few of these custom wound power and output trannies in service and not a lot to report so far.
You can get a glimpse at them on my website and maybe garner some more info from the EDCOR site. The primary impedance & wattage specifications are unique to my custom order but the construction technique is their standard.
rj
http://www.rjguitars.net
RJ Guitars
Moose wrote:The voltage change was more than 20 years ago... In the end, the B+ produced by each will be the same within a very small margin of error.
...However, M6 is not the best steel if you want to chase Franchesca tone.... So, if you're cloning an express circuit, M6 is bad.
If you're designing your own circuit around M6, or if you're getting Edcor to make you a 470 clone on M6 for the super-super clean Rocket, Then you're good to go.
Moose,
This is excellent information for all of us and I am very grateful for your input. If you could indulge a few more questions... also I know that Rhinson has done a lot of research on this topic so anybody who knows their stuff feel free to add to the answers of my questions.
1) Where does this 250-0-250 / 280-0-280 transformer for the Rocket come from? Is this the same Pacific that is used in the Express and Liverpool amps?
2) Were the Stancor A-3800 and A-3801 transformers just generic push pull transformers that were used in the Trainwreck amps and did anyone else in the guitar amplifier business use these transformers? I guess I am digging for what makes them special.
3) I am curious if we know the type of steel used in the Stancors or was the experimentation with the various steel types something that Ken Fischer was working out with Heyboer and/or Pacific?
4) Is the correct output tranny for the Liverpool the Heyboer 5200? I think Mojotone sells this transformer as the TW-5200 and Toneslut sells the dual primary version of this that we commonly refer to as the output part of the Trainwreck Tranny set... let me know if this is outa whack.
5) Is it fair to say that the 5200 is a clone of the Stancor 3800?
6) Ken Fischer was reported to go through a lot of transformers of the "Same Specification" before he heard what he wanted... does anybody know what he was listening for?
Thanks again for your help.
rj
rhinson
Post by rhinson »
hey rj, i've posted on this twice now-----once to you personally only back in dec.!!! :lol:
here...check this out and the other link inside the thread from the first response. rh
https://tubeamparchive.com/viewtopic.ph ... ght=#72520
Bruciep07
Post by Bruciep07 »
While we're on the subject, please tell me someone from here scored that Stancor 3800 that just sold on ebay, I completely forgot about it :x
OK I have read all this before, so decided to save these links to a basket so that I can go back a review some more. I am going to make myself a chart of tranny names, numbers and specs cause this subject is all over the place and no wonder I have questions regarding real Trainwreck iron.
Thanks guys I do appreciate all your responses and hope you don't get upset with our questions just needed some help sorting things out.
Richie
Post by Richie »
Bruciep07 wrote:While we're on the subject, please tell me someone from here scored that Stancor 3800 that just sold on ebay, I completely forgot about it :x
haha yes that was me..
RJ Guitars
here...check this out and the other link inside the thread from the first response. rhrh
https://tubeamparchive.com/viewtopic.ph ... ght=#72520[/quote]
rh - sorry to ask you to repeat yourself... My mind is like a steel trap! I reread that thread and indeed it sounds like the same basic question and well answered the first time - pardon my aging mind & thank you again .
I am looking for a few relative pieces of the transformer story if you can indulge my further questions:
From an earlier post in a related thread -
rhinson wrote:both the power and the output are the units i originally had made at heyboer. my idea with this particular dual hv sec was really for my own amp building usage---so i could build either a lower voltage ac30 amp (the rocket) or a higher/"norm" ac30 amp. so it was really just for my own utility. the outputs are a slightly modded a470 based on dave funk's comments about what k.f. used in this amp. rh
I think the bottom line is that I got tripped up because I wanted to think of the the dual secondary trannies we are familiar with as Trainwreck Originals and somehow missed what you said about that the first time(s). Now I believe that it was you that brought the 280-250-0-250-280 tranny to the world by providing the specifications to Heyboer and this tranny has nothing to do with the 280-0-280 Pacific tranny that is used in the Express amps...did I get that right?
I'd also be curious what you (anyone that knows) can tell us about other dual secondary trannies, did Trainwreck use them or were they also created for our convenience after the fact?
thanks
rj
Moose
Post by Moose »
RJ,
First -- the power tranny used for most stuff is the same. Even on Rockets. RH pointed you back to that, but I wanted to make it clear here.
Actually, 260 is a tiny bit low compared to what voltages we know about. 250 way too low.
RH spec'd that tranny for his own purposes. The 250 would have been about right for a Rocket if it were a 115V primary -- but it was wound against a 120V primary. Do the math:
120/115 = 1.0435
250 * 1.0435 = 260.875
Anyway, my trannies or any 120V primary 260-0-260 (or even up to 262 or 263 -- since the Rocket is uber-clean) is the correct range. If you want one wound to be right there, that's where you have to start.
The dual-secondary power tranny is directly off a KF line card, and it matches the two voltages he worked with. He spec'd this himself, I haven't changed it, and the voltages exactly match those measured and observed in real production amps, so that's handy.
Second, the stancor output trannies were off-the-shelf items that KF was familiar with. He learned about them when working at Ampeg. The later move to 6600 ohm for an express and the choice of steel was probably a refinement to suit his tastes (Remember, KF started building Trainwrecks with liverpools). As he couldn't get Stancors reliably when they went out of business, he had to spec his own "clones" or whatever you call them, and that's what we're chasing now.
What's "Special" about stancor? They sound bitchen, that's what's special. Build a good Liverpool amp with an A3801 and you'll get it. The circuit and that tranny work together.
For what steel was in them -- there's no straight answer that works. For some reason I've had good luck getting better tone out of a '70s tranny with, ostensibly, the same steel as a modern one. I've heard knife makers complain that older steel is different than modern steel of the same grade, and I don't know if it's time or formulation that makes the difference. That's voodoo magic to me.
Anyway, my steel choice and Pacific steel choice is based on what KF actually used when he had his trannies custom wound. In essence, his choice to replace the stancors.
Third -- the HTS5200 is NOT the correct liverpool tranny. It is an M6 steel stancor style that was for an experiment that KF wanted to do with hi-fi materials. Maybe it was when he was choosing steel for a clean amp like the Rocket, or something else, but it's nothing like what ended up in liverpools. This was one of the red herrings in the early days here.
The "correct" liverpool tranny is going to be an original stancor, or a Pacific at 5200 or my 5200 ohm heyboer offering. I mentioned that I have separated the line to carry more pure versions earlier in this thread. I have boatloads of liverpool trannies in stock and on sale.
All that said -- I'm not a big cloner. Use whatever you want and experiment to find your own voice. If you like Edcor, use an Edcor in your amp. If you're happy with the results, all's well, right?
Bruciep07
Post by Bruciep07 »
Good score :D
Richie
Post by Richie »
Can't remember which amp Dana put his in..liverpool i believe,or rocket.. but it sure sounds good. His was an older model with cloth leads. They are really nice sounding trannys.. if you look, you can see what time it ended [4 something AM]..i was about to nod off waiting.. :)
skyboltone
Post by skyboltone »
Moose wrote:RJ,
Actually, 260 is a tiny bit low compared to what voltages we know about. 250 way too low. <lots of snippage>
Hey Moose. I guess I went wrong on trusting the schematic on the Liverpool then. I always thought that somebody had mesured 235-0-235 on one so that's what I bought. Where did the 260 come from? What are we looking for on the plates of a Liverpool?
Moose
Post by Moose »
skyboltone wrote:Hey Moose. I guess I went wrong on trusting the schematic on the Liverpool then. I always thought that somebody had mesured 235-0-235 on one so that's what I bought. Where did the 260 come from? What are we looking for on the plates of a Liverpool?
The 331V for B+1 and the 234V over the PT have probably come forward from the original Mark Abbot material. Many years ago he did a lot of research and exchanged a lot of letters and cobbled together all that information for us, but it was just that. Pieced together from a lot of sources.
I'm not sure where the measurements came on the liverpool, but something isn't kosher with the 234 written on the schematic. I think those numbers were either someone's mistaken math (it could be possible someone did the calculation with ideal numbers and just guessed at the 234 written there) or they were one of the early rumors that got perpetuated. But they have to be wrong. Let me explain.
First, B+ on those things is like 335V, 340V, or something like that. Hot AC30 range.
Second, the B+ value written on the last posted schematic I saw was 331V.
So, let's begin with this problem. The normal full-wave rectifier, under ideal conditions with no load and no losses, would produce 1.414 times the secondary.
234 * 1.414 = 327.6
235 * 1.414 = 332.3
So, you're only getting that 330V in an ideal world with zero load. So, what's written on the schematic for B+ voltage does not match that 234V number already. However, I can see how someone did a quick divide by 1.4 and came up with the 234V figure. That's my guess at how that 234 made it to the schematic.
Anyway, in the real world you see a drop in voltage based on plate draw, resistance in windings in the PT, volt and a half drop for each pair of diodes, resistance across the OT windings (assuming the measurement is at the plate) etc., and the magic of Ohms Law.
So, the theoretical output of a 260-0-260 is around 365V (260*1.4 = 364) -- take away 25V for all the silly inefficiency of wire and diodes and such, and you're under 340V B+.
That's all a batch of logical guessing where it comes to what's written on that schematic, but the transformers from KFs line cards, including transformers he used in his production liverpools, are 260-0-260 (for the 120V primary, or the rough equivalent for the 115V primary). This isn't a secret, and Allyn's built zillions of these things with the Pacific tranny of the same voltage range. Pictures that popped up on fleabay of a liverpool even had the same PT part number from the linecard -- which is the same both for Pacific pool trannies and heyboer's dual tap trannies, incidentally.
The earliest liverpools might be different as Ginger didn't use a heyboer or pacific tranny, for instance. But anecdotal evidence is that Ginger's still in a similar voltage range.
In other words, we're pretty darned sure about these secondary voltages, and 235V ain't even in the ballpark.
That said, I don't think an amp running El84s at 300-310V would sound bad. It might even provide the benefit of a little more grind at slightly less power for the more rock and roll oriented among us, just as VVR does. Even if it isn't the same as a production 'pool, if you dig what you built, what you built is good.
skyboltone
Thanks for the feedback Moose. I see what happened then. The good news is that my transformer is rated at 225ma 235-0-235 at 120VAC in. I see real world numbers of 332-335 at the plates on a pair of EL-84 though. That's with an 8 amp 1200 volt stealth diode pair in a TO-220 package. Fairchild. Works good.
Thanks for the help.
Dan
Richie
Post by Richie »
The amp's top was also used in the shop as a cutting board for sub sandwiches
Glen, now that is funny..
Lousyatit
Post by Lousyatit »
M Fowler wrote:Moose,
Not that I want a Mercury Magnets tranny Moose, it is just that you know your trannies. Do you know if those guys at MM ever cloned an original Pacific? They advertise to send your vintage in and they will clone it.
I played an Express clone that utilized the MM "Wreck" transformers. It was bright, way too bright for me.
