At first it was ok. Found a cold solder joint and made the input the same as the express sheilded I changed V-1 more times than I can count to get rid of the hiss. Also changed the Mullard gz34 with a webber copper top this cleaned up sound. speakers green back 25 x 8 If I run a express with RCA 6v6 with a radal tonebone JS2 both amps at the same time I can't stop playing the rigg. The express has a tight high and mid range and the Rocket has a fat midrange and low end. I have some amperex e84l on order to replace the RFT el84.
Thank you all for the info to make this dream come true.
Regards Steve.
Now I love My Rocket
