 No oscillations and no undue noise (FWIW, I kept the WEM's original heater wiring loom, OT, PT and valve layout 100% as-is). I used a simple ground bus.
 No oscillations and no undue noise (FWIW, I kept the WEM's original heater wiring loom, OT, PT and valve layout 100% as-is). I used a simple ground bus.I'm still using the .0022uF/68K combination (with NO Bright switch at all) and it seems just fine with a Tele. Sounds terrific - no mud and still perfectly tolerable with Treble and Presence dimed. Caveat: I'm using a MASS to get it down to perhaps 2W output until the neighbours go out
Going to keep it this way for a week and try to get a proper feel for the amp's inherent tone before changing anything. Will also try it with an LP, too. I will definitely do something on the tone stack, because I've either misunderstood the values I've seen in the various Wreck preamps or SNAFUed the wiring of the Middle and Bass (which act rather odd).
Here's a quick low-res pic. I had to made the layout up as I went along, back-tracking a bit when I saw I wasn't going to get everything on. But it does fit on a 2-row ready-made turret board (ex-military NOS).
Thanks all - you've created a great forum. And thanks and best wishes to KF, too
