How does it sound? Well I only got to play it about 5 minutes but it does sound different from my first build. First off all, it's got the controlled harmonic feedback!
Second difference between this and my first build is that this build doesn't have the piercing high end. It's definitely bright but it's a little smoother.
Lastly, one thing I preferred with my first build was the distorted tones. The new build has a mid range thing I don't quite dig while my first build sounded more pleasing. Orange Drops vs. Mallory 150's, maybe?
More info when I test it out tonight.
Two issues I need to fix. I had to use a 250pf cap in the tone section since I didn't have a 500pf which I'm sure will make a difference in tone and the bright switch is wired backwards so down is brighter that up.
Omar
