Resonance , its not just for breakfast anymore ....
Plexified
Re: Resonance , its not just for breakfast anymore ....
Post by Plexified »
btw was the hyperlink not good that showed a motor working without power successful /? go ahead patent it . feel better now ? that patent happen before you tried to help someone , I thought so . really . Back to content . RESONANCE . Its simple man . the reason I posted . A new look. OOOH , Had to use a few more O's to emphasize the fact . WTF . Oh , I get it , Not much going on here , or in your mind . Sucks to be You .
Plexified
Post by Plexified »
clyde , I just say , you are cool bro , I think you got more in their for us all . joke all day , but just plllleeeeaaassse give us your best stuff .
vibratoking
Post by vibratoking »
4 more posts and still not one useful detail or explanation about how you designed in resonance to you guitar amp. :roll:
Clyde
Post by Clyde »
Plexified wrote:clyde , I just say , you are cool bro , I think you got more in their for us all . joke all day , but just plllleeeeaaassse give us your best stuff .
Thanks P. It's heartening that you recognize I'm not the clown here.
matt h
Post by matt h »
(deleted)
vibratoking
matt h wrote:I kinda skimmed this thread and mostly regret it... can someone catch me up if there's anything actually related to guitar amp circuits in this?
and if so, does it somehow end up having to do with design with controlled positive feedback? Because I do seem to remember one member actually did that a while back (inadvertently). Now that could be interesting. And, y'know, feasible.
To date, the whole thread is smelling up the garage like a trash can in the summer. But, there is still a chance that the OP will rescue this thread by educating all the non-believers. At this point, it is completely up to the OP...
Blackburn
Post by Blackburn »
Plexified wrote:btw was the hyperlink not good that showed a motor working without power successful /? go ahead patent it . feel better now ? that patent happen before you tried to help someone , I thought so . really . Back to content . RESONANCE . Its simple man . the reason I posted . A new look. OOOH , Had to use a few more O's to emphasize the fact . WTF . Oh , I get it , Not much going on here , or in your mind . Sucks to be You .
Matt, this is where we are, and likely will remain. Poorly written, moronic and confused ranting with a light sprinkling of musical notes, tone, cabinets or guitar. I believe it's about as technical as it will get regarding amplifiers.
RESONANCE . Its simple man . :lol:
Plexified wrote:remember my disclaimer when I began , I do not know what is happening .
John_P_WI
Post by John_P_WI »
vibratoking wrote:4 more posts and still not one useful detail or explanation about how you designed in resonance to you guitar amp. :roll:
VK it is quite simple, I somehow remember reading something, may have been on here on TAG and may in fact have been authored by Plexified that KF had a friend / shaman who would audition / feel each transformer before installation /use for proper vibrations or qualities.... Only the selected transformers by this individual were subsequently used in amps.
So there ya go VK - the resonance was built into, or inherent to, the select few transformers used by KF... :wink:
And does that mean that JM is using the sub par sloppy seconds dead transformers that KF did not??? :roll:
Blackburn
Post by Blackburn »
And does that mean that JM is using the sub par sloppy seconds that KF did not... :roll:
I actually told that story once and I heard it from Gregg Levy. This 'shaman' wasn't much of one and more like a California street nut from what I remember. Like you say, he would put his hands on the trannies and tell Ken which ones were special. When he was gone (Prison, I think), Gregg mentioned that he'd been having a certain type of therapy on one hand and was very sensitive to magnetic fields at the time, so he then became the 'shaman'. His belief was/is that the rule for special trannies is 1 in 10. Take what you want from that. :roll:
Plexified
Post by Plexified »
My point was just on resonance and a potential for a new approach . You can learn from Hendrix when he employed his own monitor amp to excite his guitar at close range . He worked with his techs constantly to adjust the resonance from his Vox Wah and his Fuzz face . It had a very close relationship and if you are aware of the information from his techs you know what I am talking about . The feedback loop I worked with extensively to tune the circuit . I have used transformer orientation considering a 3-D platform . Here it involves the tubes being radiated by magnetic orientation as swell as the capacitors as well in the different stages . Like the Marshall 12 series . Transformer with laminates facing the tubes and effecting one half of a pair or side of four tubes in a hundred watter . The magnetic radiation effecting the capacitor placement in this specific design as well . In the Tesla example it uses an external capacitive exciter to match resonances . In this event it creates a unity of sorts like a removal of drag or gravity . Again , I stated I did not understand it as I was researching it . Your circuit has a resonant point , alone . Then vibrations further influence it . Like in a combo amp versus a head . The volume and physical vibration plus the circuit resonance plus the exciting resonance of the component I am researching which uses external non connected physical connection changes the field of the Output transformer . If you know about the way to control the sag regarding the power transformer its the inverse . All very useful techniques . So , again , I am not done researching this concept . Its a lot of trial and error . Hey Harrison Ford could pilot the Millenial Falcon , but he still crashed a trainer aircraft . But he survived . He knew how to land it textbook style and saved lives . Another funny concept . I have posted a lot of relevant information and its to just to be helpful and offer interesting perspectives . I certainly did not stink up the garage .
You know, every few months a thread is started and it's off to the races.
I don't know nothing about energy pumps or whatever, but what happens to conservation of energy with these gizmos?
What is the source of energy?
Hey if you come up with a guitar amp that powers itself, people will beat a path to your door.
Your name isn't Bob is it?
Jana
Post by Jana »
So, we went from free energy with motors that run themselves to wah pedals and dangling capacitors in the magic zone around a transformer. Where does the anti-gravity and the way-back machine fit in with this? Mind sharing what you're smoking?
Oh, do us all a favor and buy this: http://www.amazon.com/The-Elements-Styl ... 020530902X
What?
Plexified
Post by Plexified »
Hello all ,
mistake noted . Not enough for you to understand . I was excited about the potential of technology that could offer new avenues to guitar amps . I am amidst research as I mentioned . Why is it so hard to just open your minds to new potentials without becoming snide . Like I said jokes are fine , but I find that to just make fun of someone is kind of weird . Because from my perspective you do not understand what I am talking about . That's fine , I did my best to explain . But your the ones degrading the content here . I just perhaps jumped the gun because I thought it was a concept that could be understood . Granted , when I first came across Tesla his work was very fragmented and plans were confiscated . However , that has changed and the information is allowing people to use the original plans to actually make the things he spoke of . I just do not understand why your getting hostile with me . This guys life was the most enigmatic work that makes Einstien look like a few decades away from catching up . A Beginning for Quantum Mechanics, physics and the furthering of mathematics was Tesla and he was slandered , ostracized and eventually killed after his work was stolen , his factory burned down and he was marked as forbidden regarding the continuation of his work by his close engineers . You put me in a position to view you that have posted as trolls and government heavies . Its foolish . Or its serious . I think that if you like the faction of harmony and the concept of vibration and resonance to further the physics its not a hard bridge to make . Who is smoking who here ? Don't like my post ? don't read it . I am not going to get to the level of Clyde , and just cast stones . Tune your circuit . Go ahead . You will have to understand some fringe speak to get what I am talking about . Free energy attacks are so stupid and disclose how your not in tune . The great ideas have been bought and will not see the light of day as a result of the persuit of capitalism and big oil . It was clear as day in the Tesla commentary . Edison was the guy to put a meter on your house so you could be charged . Tesla showed we can do it for free and and raise the human experience . They killed him because of it , and now you pay . And apparently I get treated like a clown ?. So forget it . Like I said , if its not your cup of tea , tune it out .
Blackburn
Post by Blackburn »
You have offered NOTHING. It seems that it's difficult to teach what you don't understand...
You keep furthering this thread with your uselessness. You're always going on about scapegoats, aren't you? Some reason why it hasn't come into fruition or why it can't be used for free. The government, oil, capitalism, etc. Get over it.
Plexified wrote:Back to content . RESONANCE . Its simple man . the reason I posted . A new look.
Please explain just how simple it is. Had you done so in the first place, things would not have turned out quite like this.
Clyde
Post by Clyde »
I don't mind being your scapegoat P. I ask for evidence and you produce what?
That's right, nada. The things you say about Tesla are total bullshit, the videos you post are the same and you want everyone to believe that your resonance theories are, unlike most of the the other things you believe, based in fact. Doesn't resonate with me.
I'm not the guy that told you to F off, perhaps I should have, but I'm "cool."
