can i take any 18wat power supply and mend it to the rocket pre amp and pi ?
how would i configure it to use 2 el84's though
18 watt rocket ?
Re: 18 watt rocket ?
There have been a few of us trying different things to come up with a 15- 18 watt Liverpool. The Rocket would pretty much be the same. One of the problems you will have even using the Rocket PI is that your B+ voltage will be higher than that used in the rocket if you stick with the 18watt power tranny.
Here are a couple of threads
https://tubeamparchive.com/viewtopic.php?t=3310
https://tubeamparchive.com/viewtopic.php?t=3302
https://tubeamparchive.com/viewtopic.php?t=3086
