6v6 mini wreck ?
Ghandi
6v6 mini wreck ?
Post by Ghandi »
hi all,
I'm thinking about building a mini wreck at some point in the future
and I have some questions:
isn't a se el86/84 a bit too much on the treble side for a wreck preamp?
wouldn't it be a bit more on the train wreck side with one 6v6 instead of the el86 / el84?
has anybody tried a derailment kind of amp with a 6v6?
sliberty
Re: 6v6 mini wreck ?
Post by sliberty »
My MiniWreck supports a single power tube, which can be either an EL84, a 6V6 or a 6L6. It has a 9 pin socket and and 8 pin socket to support this (one at a time of course). You can also use an EL34, but the power trannie I have been using might e a little small for that tube from a current perspective. The next builds will use a beefier PT to better support the EL34.
I find the 6V6 to be my favorite tube in this amp, with the EL84 as a close second. It's not so much a matter of brightness, but rather the character of the crunch. Actually, the MiniWreck is not nearly as bright as the Express, probably due to the lack of a PI (resulting in less overall gain), so being overly bright is not an issue for me.
Ghandi
Post by Ghandi »
hey sliberty,
thanks for that info!
brings me to another idea;
couldn't the PI stage be simulated with the unused 12ax7 half
and how would you bias the stage then?
sliberty
Post by sliberty »
I decided not to use the unused stage, because I wanted the preamp to more closely resemblethe Express. But there is no reason you couldn't have a 4th stage in the amp. You could arrange it like the 3rd stage = 10k and no cap I suppose, or use alligator clips and do some experimenting.
Ghandi
Post by Ghandi »
mh,
what would happen if you add a 470ohm resistor between the catode and the 10k resistor and than add a 1m resistor from that connection to grid, just like a half PI stage.
would that make the stage act more like the PI or is that nonsense?
Ghandi
Post by Ghandi »
oh,
and couldn't than also be the negativ feedback and prescence control be added just like on a real wreck?
