Talk to me about Concorde/KF50 Transformers
Re: Talk to me about Concorde/KF50 Transformers
Roe wrote: mine sags quite a bit
It happens to the best of us as we get older :oops:
lgehrig4
Post by lgehrig4 »
pablogt wrote:
lgehrig4 wrote:
I saw that one. Very nice! Doesn't look stock. Could you tell us about the mods you added?
Apart from the layout itself it's all quite standard. Let's see: Footswitchable fast/slow modes (with some voicing tweaks in fast mode for lead work), power scaling (London power SB1), dual bias adjustment, fuses for B+, heaters and relay power suply (I'm using the 5vac rectifier tube heater supply for that) and three very small rc filters before and after rectification for cleaning up diode switching noise. Heater voltage is elavated by about 70v+. Some voicing tweaks too, to make it cut through the mix better.
Pablo
:shock: Whoa! How many more mods before you consider it non-standard?
pablogt
Post by pablogt »
:) I mean that most of the changes are there to reduce hiss and hum or to improve reliability and not to change the voice of the amp, with the exception of the changes in couple of cap values...
Pablo
