wiring
FE911
wiring
Post by FE911 »
Sorry, I was trying to add this to another thread already started. A little help from the moderators!!!!!!Kind of backwards-ass method of wiring. Looks like something I would do!!! But I would like to see the right side to see what has been done. I'd say get the heater wires finished, big black and red wires. Those usually come first.
I would also print out Nik's layout, and check off everything that has been done already. Make sure everything is where it should be. That was a problem when I got a half-finished build. Then note what still needs to be done(make sure you have everything). Looks like you have a good bit already done! Just a few hours of solder sniffing to go!
