Rocket Group Build project
Re: Rocket Group Build project
My Express build is definately louder than my Liverpool. Don't get me wrong, the 'pool is still very loud. Actually and sadly too loud to play with my band in our practice booth so I have to use an atenuator.
Timo
						Timo
I agree. The Express is 5 to 10 watts louder that the Liverpool. But like you say the Liverpool is still loud and so is the Rocket. Have you tried 6V6s in your Express? The Liverpool, and the Rocket too, are both Cathode biased and as such lend themselves very well to power scaling.ODwan wrote:My Express build is definately louder than my Liverpool. Don't get me wrong, the 'pool is still very loud. Actually and sadly too loud to play with my band in our practice booth so I have to use an atenuator.
Timo
Dana,
I plan to power scale my Liverpool someday, but suitable pots are hard to get here in Germany. I know Ican order trough Digikey, but they have a €100,- minimum order. So I wait till I have enough to order. Money is an issue, too these days
I've tried it with some zeners on the CT but the amp lost his feel completely. I guess you just have to scale the powertubes and install a limit control.
And yes, I have tried 6V6s in the Express but I just like EL34 better.
Timo
Timo
Timo
I just use a standard cheap alpha 1/2 watt pot for the scaling control. It has a lot of voltage on it but very little current. I also like to scale the whole amp instead of just the power section. That way you don't need the extra drive control. If you can get your hands on an old blown up computer power supply you can usually find a big power mosfet in those that you can scavage for free. Total parts for doing a liverpool would be 1 pot, 2 resistors, a zener diode, and a mosfet. Should be less that $5us if you can get the mosfet for free.
Diana has a tube rectifier.UR12 wrote:It is interesting to note that Paul didn't use the choke or tube recto and Diana turned out nice by all reports.
Dana,UR12 wrote:Timo
maybe I'll give the Alpha a try, though it is barely within it's rating. Have one 1Meg lin lying around together with a IRFP840. The other components are available at a local store. Also I have that Cut control on my 'pool which is easily converted to a limit control. ...and it's already tight in the chassis.
Timo
Johnjohnspeck wrote:Diana has a tube rectifier.UR12 wrote:It is interesting to note that Paul didn't use the choke or tube recto and Diana turned out nice by all reports.
I stand corrected.
 I was thinking he used  SS diodes and 1k resistor in Diana. Am I wrong about the choke also?
 I was thinking he used  SS diodes and 1k resistor in Diana. Am I wrong about the choke also?Re: Rocket Group Build project
Nope, you were right, no choke.
I finally got around to building a head cab for my new Rocket and thought I'd give you a look of it in it's new home. I took the non traditional approach and built a tolexed cab instead of the cherry.
Is there a schematic for power scaling??
Thanks!
						Thanks!
Thats a great lookin Rocket there Dana ! I like that look.  Chad
						- RJ Guitars
Any Rocket Sound CLips?
I'm a bit curious of this project.  I've got a chassis that seems to be right spec for a Rocket, Liverpool, or an Express and I'm just starting to get my layout marked out on it.  I'm still deciding between the Liverpool and the Rocket and I won't drill any holes until I get that decided.
I'd be interested in some clips of a Rocket if anybody has them...
thanks,
rj
thanks,
rj
http://www.rjguitars.net
