liverpool build
mark enger
liverpool build
Post by mark enger »
I cant open the file for the liverpool layout by ron worly all i have is a black and white copy and cant make out the values of the dropping resistors, and i cant realy see what going on with resistors r32 a and b looks like there tied together but im not sure mark
John_P_WI
Re: liverpool build
Post by John_P_WI »
Yes, R32a and b are tied together, in series. Both 9k1, 2 watt.
R31 = 1k 25 watt
R33, R34 are 9k1, 2 watts.
Hope this helps.
Edit: Fixed typo on R31
mark enger
Re: liverpool build
Yes that helps alot if someone could post the layout itself it would really help mark
rock_mumbles
Re: liverpool build
Post by rock_mumbles »
R31 is 1k - 25 watt
Gibsonman63
Re: liverpool build
Post by Gibsonman63 »
Layouts
https://tubeamparchive.com/viewtopic.php?t=5677
https://tubeamparchive.com/viewtopic.php?t=20
There is a 3D version on the second link that I found very helpful.
I will be well worth taking the time to move them to a thumb drive and getting them printed in color on 11 x 17. Get a couple of extra copies for troubleshooting.
mark enger
Re: liverpool build
Thanks guys got it, now i can finsh up, heres a pix I mounted a capcan in the chassis now to fit the rest of the electrolytics, i may just mount them in there sections on the board once again not enough pre build planning mark
