Speaker recommendations for a Rocket-based amp?
Curly
Post by Curly »
Howdy all.
I have a custom built Rocket based amp on order, and it should be done soon.
It looks like I will likely get an Avatar vintage 2x12 cab.
As of now, I'm leaning towards a combination of either a Weber Blue Dog alnico/ Silver Bell alnico, or Blue Dog/ 1230 ceramic (G12H type).
I'm going for a Vox/ Marshall tone. Once I nail down the speaker choice, I'll probably ask Ted about power rating - likely either 30 or 50 watt versions.
What say ye gentlemen regarding these choices?
thanks kindly!!
"music heals"
HeeBGB
Site Admin
Re: Speaker recommendations for a Rocket-based amp?
Post by HeeBGB »
Celestion Heritage G12-65 and AlNiCo Gold! That's my vote anyway!
philmanatee
Post by philmanatee »
I'm using Altec 417 with paper dustcap and reconed Celestion blue. Phil
johnspeck
Post by johnspeck »
I use my Rocket with either of two cabs. I have a Marshall basketweave 4-12 straight loaded with G12M-25/75hz Greenbacks, and a style-II Bluesbreaker 2-12 semi-open-back (big*11.5" deep, around 2/3 of the 4-12 dimensions) loaded with 2 Weber 30-watt alnico Blue Dogs. The 2-12 is my choice for my loud rock band, as it is a louder cab, and I'm playing with another guitarist with a 50-watt half-stack. My 4-12 with the less sensitive Greens isn't loud enough. Both sound good, but the amp really sounds different at the same settings depending on the cab choice.
Curly
Post by Curly »
thanks guys ... I appreciate it!
john, thanks ... the amp you posted had a lot to do with my choice ... mine should turn out similar to yours, so I appreciate the feedback
I'm leaning toward the Celestion Blue/ G12H combo, or a Weber Blue Dog alnico/ Silver Bell alnico combo. One advantage with Webers is that you can spec 15, 30, or 50 watt versions when you order to match the amp's power
"music heals"
Clyde
Post by Clyde »
I built an AC30 for a local player, he went with the Blue Dog/Silver Bell
combo. I also liked (more actually) the Silver Bell/G12H30-55 combo.
It will be going into my Rocket build coming soon.
pureoldsound
Post by pureoldsound »
I am planning on using some Alnico blue Dogs 30W with my Rocket...
