	Moderators:  pompeiisneaks , Colossal
								Colossal
		Posts:  5205 Joined:  Sat Oct 20, 2007 9:04 pmLocation:  Moving through Kashmir
						Post
								by Colossal  Wed May 27, 2009 3:07 pm
			Zippy wrote: M Fowler wrote: I plan to have engineering change the PT to 300-0-300/6.3 10A/no bias tap for future builds as well.  The PT I have coming is 315-0-315/6.3v 10A.
OK, it's late (for me)...  Why no bias tap?  Are you going cathode bias?
I see bias test points on the back panel so I'm thinking that's not the case.  What am I missing (besides sleep)?
Zippy, Mark is just tapping voltage off an HT secondary and then putting a fat resistor in line to tame it down to bias voltage levels.  Similar to the way it's done in the 2xEL34 Expresses.
Dave
								Zippy
		Posts:  2052 Joined:  Tue Apr 25, 2006 11:18 pm
						Post
								by Zippy  Wed May 27, 2009 6:55 pm
			Gotcha.  Thanks.
								Flash
		Posts:  16 Joined:  Wed Sep 07, 2011 1:59 amLocation:  Toronto
						Post
								by Flash  Mon Sep 19, 2011 12:43 am
			I know i am way to late on this thread but i am curious to how the different builds went on this 80 watt express? I am glad i found this because i wanted a express but 40 watts is not loud enough. I am going to get someone to build this from me. Can't wait to hear this amp. Is there any clips out there? or any photos of builds? Any input would be much appreciated. And thanks for making this amp!
		Posts:  14036 Joined:  Wed Jan 16, 2008 2:19 amLocation:  Walcott ND
						Post
								by M Fowler  Mon Sep 19, 2011 2:57 am
			Allynmey did great but my 80W Express was uncontrollable so I made it into a Rocket with reverb.
		Posts:  10189 Joined:  Sat Feb 14, 2009 4:38 amLocation:  GA USA
						Post
								by Reeltarded  Mon Sep 19, 2011 3:45 am
			Thanks for dragging this up. You should see what I decided to do to my uhoh'd Majors.
.. and you will! Sort of soon if I can just get a couple other tings out da way.
								Flash
						Post
								by Flash  Mon Sep 19, 2011 3:48 am
			M Fowler wrote: Allynmey did great but my 80W Express was uncontrollable so I made it into a Rocket with reverb.
Uncontrollable? so this means it's not an easy amp to make i guess?
								guitardude57
		Posts:  355 Joined:  Fri May 15, 2009 6:19 pmLocation:  Austin, TX
						Post
								by guitardude57  Mon Sep 19, 2011 3:49 am
			Cool...... looking forward to seeing what came up with this!
									Mike
						Post
								by M Fowler  Mon Sep 19, 2011 12:59 pm
			Well if people think the regular Express is hard to control with lead dress try 80 watts.
						Post
								by M Fowler  Mon Sep 19, 2011 1:00 pm
			Double post.
								Flash
						Post
								by Flash  Tue Sep 20, 2011 6:27 am
			M Fowler wrote: Well if people think the regular Express is hard to control with lead dress try 80 watts.
So i am guessing your the only guy that tried this build?
						Post
								by M Fowler  Fri Sep 23, 2011 8:38 pm
			Yeah I am kind of a glutten for punishment.
								Colossal
						Post
								by Colossal  Fri Sep 23, 2011 9:20 pm
			Mark,
						Post
								by M Fowler  Sat Sep 24, 2011 1:28 am
			Dave, I think it was the wire color, thanks bud!
								Flash
						Post
								by Flash  Tue Sep 27, 2011 5:52 am
			so there are some out there. I got to get one of these made. So guess i should talk to one of these other builders. Thanks for all your responses.
								Roe
		Posts:  1918 Joined:  Thu May 31, 2007 2:10 pm
						Post
								by Roe  Tue Sep 27, 2011 10:36 am
			I'd like to build one of these but transformers are hard to find
