Its Alive!!!! New Rocket build, first impressions
azatplayer
Re: Its Alive!!!! New Rocket build, first impressions
Post by azatplayer »
Beerman wrote:Crafty,
Hi.
Another Melburnian here. I'm in the middle of a 'Rockster' build at the moment, it'd be good to get together and compare notes when we're done.
Let me know if you're interested.
Cheers
graham
Another Melbourne lad here, keep me posted of a rocket ampoff! Will bring mine too!
Gargoyle
Post by Gargoyle »
Hey Mark, gave your suggestions a go.... Wow its not bad at all mate.
I found it tightened the bottom end a bit and you can dial in quite a balanced tone whereas no particular frequency seems to stand out.
Cheers
Good to hear!
I have built a lot of different styles of Rockets and modifying the circuit a little has been fun. I always seem find the need to add a bright switch :roll:
I like adding a boost switch on V1b adding a 10uf/25v e-cap or a SPDT switch and put a 10uf and 25uf option as a boost function.
A tone stack bypass option would be fun to try some time.
