Hay guys,I'm doin' last part for my build,a face plate,and I got few questions.
Are 2" x 17" good measures? I got chassis from Ceriatone,so I'm just wondering.
Is 1/16" thin enough?
Designing a faceplate
Re: Designing a faceplate
17" x 2" is standard. Check Mark Abbott's layos for more info (should be somewhere in the files section here).
traditional faceplates are 1/8th and require the long shaft pots or the faceplate mounting holes to be sunken.
1/16th works with normal shaft pots.
My Daughter Build Stone Henge
andy_wreck_fan
I'll made it from 1/16" then,maybe a walnut,will see l8r.
Thx for the tips guys,I made it first in 2" x 17" dimension,then I added it to a another file sized same as a opening for front panel in head box.
I took those dimensions from tw cabinet plans on this site.
I hope it will all fit on paper,then I'll make it on wood this week.
I'm planing on doin' back panel too,just need to find some good measures for power chord jack.
- RJ Guitars
Andy,
If you can get good1/16" stock it eliminates the trouble with having to use the long shaft pots. Most wood guys I deal with claim they make a lot of scrap in attempting to make the 1/8" panels.
I have some expensive panel nuts with an extended internal thread that work with the 8mm ALPHA pots. This lets you get the wod as thin as you can and then use the more affordable pots no matter what that panel thickness is.
Post up a photo for us when you make some progress, I'd enjoy seeing how it comes out.
rj
rj
http://www.rjguitars.net
andy_wreck_fan
my 1/16 will be done when I pick up the wood,got a friend who is a woodworker,and a very good one.
sure,I'll post some pics,after testing on paper to see if I got it all right
andy_wreck_fan
everything seems to fit on paper,so now I can't w8 to test it on wood
will post pictures soon
__
btw,just a quick question related to sound
talking to one of the guys I know (and has a TW clone),and he says that when u powerscale down the amp and put it on a cabinet that has enough bass and deeps(like orange) u can get into this teritory
http://www.youtube.com/watch?v=tkhehBugESo
is that really true?
__
