express build progress pics
WhopperPlate
Re: express build progress pics
Mike, Likely you didn't wire tranny wrong, seems fine from pics, probably more what Fowler was saying.
I'd also try testing for continuity/resistance with a multimeter from every point along the B+ line to see if there is a cold solder joint.
Charlie
Tw
Thanx Mark,Do you know the best replacement and where I could get it fast for the tc-75,Mojo has a 22 uf -450 I think its a tad,That would be OK?
Thanx Mikey
Thanx Mikey
If not rjguitar, did you try allynmey? Can you get another brand locally 20-22uf/450-500v until a TV-75 cap comes in?
I have a bunch of IC electro and some others.
http://www.hoffmanamps.com/MyStore/perlshop.cgi
http://www.mojotone.com/
http://store.triodestore.com/
http://www.tubesandmore.com/
http://www.tubedepot.com/index.html
- PlinytheWelder
Thanx
Thanx Guys,I ordered a illinoise cap,Should be here in a day or so,And rj will be back friday if I need the good one.So hopefully Ill be playing this thing in a few days,Thanx for all the help Guys,Mikey
Cliff Schecht
I've seen a few people griping about IC caps but I've personally had nothing but good experiences with them. YMMV
Cliff Schecht - Circuit P.I.
I've got at least 5 builds with those caps some of them gigged for over 4 years and never had a problem either. Might be some disinformation from the sprague lovers (or Gerald Weber lovers) out there...
D.
D.
Lets spread more rumors and keep the IC's to ourselves guys.
They work perfectly fine in my builds.
- PlinytheWelder
I just put some IC caps in an old Gibson GA-8T last week for someone and they worked out great.
Gary
